Speed Sensor
Old Jan 13, 2005 | 11:14 AM
Zokal's Avatar
Car: 1989 Firebird Formula
Engine: Chevy TPI 350
Transmission: A/T 700 R4
Speed Sensor
I had a trouble code come up saying a problem with the speed sensor. Where is it located, and what purpose does it serve? Also, could this be why my transmission does not shift to 2nd gear accurately. (It takes a while to shift)
Old Jan 13, 2005 | 04:05 PM
scubas_90rs's Avatar
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
your speed sensor is what makes the speedometer work. it is located on the tailshaft of the transmission on the drivers side. check your tv cable and make sure it is adjusted correctly. i'm sure some one that is more knowelable in automatics will let you know if there is anything else to check.
Eric2ndGen
Nov 5, 2015 01:51 PM
angel2794
Sep 8, 2015 06:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
