LS1 Driveshaft
Old Jan 19, 2005 | 01:36 PM
klumb15's Avatar
LS1 Driveshaft
is this a direct bolt in...is it any better than the stock 3rd gen shaft?
Old Jan 19, 2005 | 01:52 PM
SilentBob's Avatar
Car: it doesnt really drive right now
Engine: 383
It's a straight bolt in and its lighter than the steel shaft.
Old Jan 19, 2005 | 05:01 PM
klumb15's Avatar
any stronger?
Old Jan 20, 2005 | 02:10 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
The LS-1 makes more horseys, so I'm gonna go out on a limb and say yes.
I did this swap as well. It's one of the few where you actually notice a difference.
Old Jan 20, 2005 | 03:14 PM
klumb15's Avatar
ic ic...couldn't hurt tho...whats a good price to pay for one?
Old Jan 20, 2005 | 03:31 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Max price for a used one in good condition with both end yokes, $150.
Old Jan 20, 2005 | 03:34 PM
klumb15's Avatar
alright...thanks..
Old Jan 21, 2005 | 11:35 AM
Car: 83 Z28
I paid $125.00 for mine so that sounds about right.
Old Feb 4, 2005 | 10:45 PM
A10Beav's Avatar
Engine: LS2
Axle/Gears: Moser Ford-9, 3.50
I went to a parts lot to look for one, and they told me there were two different sizes. Which one fits?
Old Feb 5, 2005 | 12:15 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Go back and tell them thier morons.
Old Feb 17, 2005 | 10:24 AM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
im with pasky.....but yeah i got a LS1 alum. driveshaft on mine and it was easy to put on .....as for performance i do hear my transmission thump 3-4 times more than with the original driveshaft-broken rubber trans mount i guess it spins it easier or something
Old Feb 17, 2005 | 04:27 PM
Car: 83 Z28
Mine had a 4.11 in it with a t5, maybe it was more noticeable.
Old Feb 19, 2005 | 04:49 PM
Marc 85Z28's Avatar
They are right. There are 2 different LS1 shafts. You moron
There are 2 types of LS1 shafts, steel and aluminum. They both directly bolt on.
Old Feb 19, 2005 | 06:03 PM
A10Beav's Avatar
Engine: LS2
They actually told me there were two lenghts available. Is there a difference between an auto and manual car?
Marc, the electron blue must look great on the car
Old Feb 19, 2005 | 06:27 PM
Marc 85Z28's Avatar
I have a feeling they might be confused. There are 2 different types:
The 2.5" steel shaft. Found on 2.73 geared autos.
The aluminum 3" shaft. Found on 3.23 geared autos and all 6 speeds.
And although there might be a difference in length, it is very minimal, and the 2 are still interchangeable.
I am running an original 6 speed LS1 shaft in my 700r4 equipped car. And other than a lighter wallet, a slightly lightened driveline, and the inability to remove my driveshaft with the rear drooping (4" Mufflex), I saw no performance gain whatsoever.
And the paint looks great, even after 3 years! Thanks!
EDIT: The aluminum LS1 shafts incorporate a damper in the shaft, helping to eliminate driveline vibration and harshness. It cured the vibration I had at high speeds, which seems to be a common problem. I believe this same shaft is recommended for this same concern in a GM TSB.
Old Feb 19, 2005 | 06:50 PM
A10Beav's Avatar
Engine: LS2
Thanks for the info. So you didn't see a gain? I thought less rotational mass would give a little better acceleration. Oh well. I think I'll still do it though, I want to lighten the car where I can, to help offset the weight it's gained from SFC's, larger sway bars, etc. The dampener should be nice too.
Old Feb 20, 2005 | 06:15 AM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
When I can finally drive mine again, I'm getting one just for the dampner on there. I had a vibration with my old setup, but with a new motor and soon a trans, maybe it already went away?
Old Feb 20, 2005 | 07:32 PM
pasky's Avatar
No, he was referring to the aluminum. Im quite aware of the steel shaft that was put in automatic v8's with gearing lower than 3.23. Either way, their both the same lengths. Once again, their morons if they think the steel is longer than the aluminum.
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
