differential question
Car: 1992 Camaro RS
Engine: 305 V-8
Hello,
Just wanted to know if someone could tell me what differential I have in my t/a. I have a 1987 GTA with the 350 posi rear end and disc brakes out back. Just wanted to know the ratio.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: differential question
Originally posted by irocznut
Hello,
Hello,
Car: 1987 TA
Engine: 350 stock/twecked
if you put the car up on stands and pull the cover the ring gear has the ratio on it. no need to count teeth unless it is not the factory gm reat end
later and
GB
rick
later and
GB
rick
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Well if that is the stock engine with the stock rear end then you should have a borg warner 9 bolt rear with 3.27 gears. The back cover of the differential should have a white sticker on it with 3 numbers and/or letters. If you have the 3.27 then it will be 4EU. If the number is something else than you would have to look it up on the internet.
EduardoRonaldo7
Sep 8, 2015 01:28 PM
red90IROCls1
Aug 25, 2015 06:56 AM
