which holes?
Car: 1988 Camaro SC
Engine: 383 Stroker
Transmission: TH-350
which holes?
I have a dual bolt pattern flywheel and a dual bolt pattern converter. Should I use the holes farthest to the inside or the outside? Both sets line up.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Dual bolt pattern is for Powerglide, TH350, 700R4 etc on one bolt pattern and TH400 on the other.
If both the flexplate and torque converter are dual bolt pattern, it doesn't matter which pattern you use. Install them into the holes that are the easiest to access.
Pac J
May 17, 2020 10:44 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
