what's the diffrance between LS1 and LT1 T56?
Old Feb 9, 2005 | 05:21 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
just curious, I've seen allot of LS1's around and I was wondering what it would take to install one
Old Feb 9, 2005 | 08:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The length of the clutch gear
What it would take to install one, is a LS1.
If you're going to mate it up to a pre-98 motor, it needs to be the LT1 variety.
Old Feb 9, 2005 | 05:06 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Input shaft and front case plate. Replace both and reshim the trans to change the parts out.
There are a handful of ways to use an LS1 T56 behind a Gen I or Gen II SBC. I'll come back later and elaborate.
Old Feb 9, 2005 | 05:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Which means:
Yes can can make a LS1 transmission fit a Gen 1 SBC. You buy 2 transmissions. One is the one (LS1) that doesn't fit your car, one (LT1) is the one that does. You take them both apart; put the parts out of the one that fits, into the one that doesn't; now it fits. Throw away the remaining parts, or if you're lucky, sell them. Don't bet on it.
Or, just buy one transmission, specifically the one that fits; don't take any transmissions apart at all; and don't throw away any transmissions.
So even though something is possible, it may not be practical, or at best, certainly not the wisest route to take.
Just get the right transmission in the first place, and forget about the LS1 ones.
Old Feb 9, 2005 | 05:19 PM
jmd's Avatar
jmd
There are adapter plates so that the LT1 trans. parts are not necessary. I'll let you know how that goes on a friends SBC.
Old Feb 9, 2005 | 05:48 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
just get one from McLeod.. same LT1 length.. but has the better push type clutch like the LS1.. the LT1 had the pull type.
better gearing from McLeod, plus the steel forks, and viper input shaft.. 1st gear is 2.97 with a final of .63 the lt1 has a .50 final i forgot the 1st..
Old Feb 9, 2005 | 07:53 PM
Engine: 383
OK, so LS1's defenatly wil not fit....what are the external diffreances that are easy to see, I'm trying to get all my parts lined up before I get back, but the only way I have is through my father and online, and some people don't know what they have and all I have to go on is pics.
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
