Rear Gears and Differentail Question
Old Feb 12, 2005 | 04:02 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
Ok, im pretty sure i have a 10 bolt (i counted them last time i was under my car, but it was like 4-5 months ago)
anyways, i want to get a 3.73 ring and pinion and a posi unit.
so what exact do i need, will any 10 bolt ring work? i was lookin on ebay for them, anything i should look out for?
Old Feb 12, 2005 | 04:56 PM
ede's Avatar
ede
you need a carrier to match your axles, or buy a carrier and then buy axles to match it. you need a gear set to match the series carrier you have, or a gear set for your carrier that is made to fit, but not in a factory ratio, or a gear set and shim to make it fit your carrier, plus all the related parts needed for the installation
Old Feb 12, 2005 | 06:45 PM
Borsty's Avatar
Car: 89 Trans am
ok i was looking at some on ebay, they said like 8.5 and some other inches, so is that how much girth the posi unit needs?
Old Feb 12, 2005 | 07:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Those are for the old Chevy 8.5" inch 10 bolt, your car has the new 7.675" "GM corporate" 10 bolt. You'll need to find a posi for the 7.675, there's nothing interchangeable between the two.
Old Feb 12, 2005 | 08:42 PM
Borsty's Avatar
Car: 89 Trans am
thanks that exactly wat i was wondering.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
