hi
I was driving my car today and for the first time I heard a noise coming form under the arm rest, I made a turn and then push hard on the gas and has the transmission geared down I heard a transmision slipping sound, to me it sounds like one of the mounts on the transmisiion or 2 are dead and I m goign to drive it easy until I get some feedback from you to see what I should do about it
thanks for the help in advance
cedric
cedric
Ok well first of all how do you hear a transmission slipping? Did the revs shoot up? Car shudder?
Secondly, and believe me, you will hear this a LOT, it sounds a lot like the mount to me. Replace it. And there is only one. Replace it with a poly one, it's worth the extra money.
thanks, can I do this without lifting the car or should I take it to a mechanic, how long do you think it would take to install it? (I dont want the guy to charge me 3hours of labor if it takes 5 minutes !! they love doing that)
do you have a link for that poly mount to a store ??
thanks goodnight
thanks goodnight
Sure thing. Here's the mount: http://store.summitracing.com/partde...=KeywordSearch
And it took me less than five minutes, but I had shop facilities.
Here's what you do:
-jack the vehicle up (I used a 2 post hoist
-place a jack under the transmission pan, and be sure to ude a 2x4 or something to prevent damage to the pan (I used a trans jack and some 4x2)
-loosen the nut that goes from the mount to the crossmember (I had to use an impact gun to get it off)
-jack up the trans a few inches so the bolt will clear the hole in the crossmember
-remove the 2 bolts holding the mount to the trans and remove the mount
-install new mount in the reverse procedure, torque it to spec
-lower vehicle
-dance
Here's what you do:
)-place a jack under the transmission pan, and be sure to ude a 2x4 or something to prevent damage to the pan (I used a trans jack and some 4x2)
-lower vehicle
-dance
thanks a lot
I cant do all those things( no room to work on the car), how long did it take you to do it
I m goign to have a shop do it so I just need labor from them
thanks
thanks
Like I said, it took me 5 minutes with all shop facilities at my disposal. I'd say walk if they want anything more than twenty bucks. And ask for the old one back.
thanks a lot i m goign to do that,
If they tell me its an hour or two of labor, i ll report it to local shop review
thanks again
Cedric
thanks again
Cedric
