proper gear for speedo
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
need to know the proper gear to put in my 87 5speed, I am running 373 gears ... and will these replacemnt gears fit a speed sensor ..... anyone know the tooth count i need and where do I buy one
Car: 92' B4C Camaro
Transmission: G-Force T5
Are you still runing Factory size(Diameter) tires? If so what is the Diameter?
What was the Factory Rear Gear Ratio in your rearend?
This will help determine what Drive Gear & Driven Gear you have in your speedo.
From there you can use the Calculation in the Tech Articles.
235/60/15
factory ratio in the rear is 373 to, I got the rear from a 84 with these tires, the 5 speed is a 87 Z-28 box
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Do a search on jmd, a member on the site. He hooked me up with the correct sleeve and speedo gears (drive and driven) for 3.73s.
JamesC
JamesC
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
