TCI or Painless?
Old Feb 16, 2005 | 08:49 AM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
TCI or Painless?
I'm getting ready to order a TC Lockup Kit to install on my 700r4 tranny. I'm not sure which company to order it from. I've got it down to either the TCI Lockup Kit or the Painless Wiring Lockup Kit . I'm leaning towards the one from Painless. Will this work well with my setup.
BTW...my setup is a L69 305 w/ Holley 600 Carb, GM Performance Manifold, MSD Distributor, No EGR, No Cat, No smog pump, No computer, and Dynomax exhaust
Old Feb 16, 2005 | 12:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Both kits contain some parts you don't really need, or already have. It's pretty easy to do it yourself without a kit using a few parts available from the dealer, not to mention cheaper.
Old Mar 3, 2005 | 03:37 PM
kamu's Avatar
Car: 84 Z28
Engine: 400
Transmission: tex racing t101a
Axle/Gears: 4.56
What parts will I need to do this?I will be putting a 700r4 from a 92 van with a 4.3 into a 86 trans-am with a carbed 350. The computer has been removed from the car allready. also the car has a electronic speedometer. I bought the car with no engine or tranny. I would like to be able to hook up the speedometer. I will be running 3.73 gears. thanks for any help.
Old Mar 3, 2005 | 07:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Your transmission might have a VSS to drive the speedometer already, I don't know. Exactly what you need will depend on what wiring your car still has, and what the wiring inside your transmission looks like. Check here for a start: https://www.thirdgen.org/techbb2/sho...hreadid=230910
84LsxZ28
May 17, 2020 02:21 PM
88CamZ
Oct 8, 2015 10:29 AM
roysatikas
Sep 7, 2015 08:08 PM
Fox118
Sep 1, 2015 04:07 PM
Eric-86sc
Aug 24, 2015 09:01 PM
