Flywheel To Pressure Plate
Old Mar 1, 2005 | 06:45 PM
JesasaurusRex's Avatar
Building a 406 with a 2 piece rear main seal and internally balanced. Planning on using the stock 10.4" type pressure plate for a third gen T-5 type tranny. It is a centerforce dual friction kit. Basically im replacing the flywheel with one that is made for a 2 piece rear main seal. Wanted to know if this would bolt up to my pressure plate just fine with no problems, already know itll bolt up to the crank.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Thanks fellas
Old Mar 2, 2005 | 07:46 PM
brutalform's Avatar
I dont see why it would not. I had a SPEC 10.4 flywheel and Stage III clutch, and I ordered it to fit my 436 with a 2 piece seal. I was able to set my D/F pressure plate on the SPEC and all was the same. If you buy a 10.4 flywheel, all 10.4 pressure plates would bolt up.
Old Mar 3, 2005 | 02:35 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yep!
Been there and done that myself on my 383 which has the 2 piece RMS. Used a McLeoud flywheel on mine....
Old Mar 3, 2005 | 08:09 PM
yup thanks fellas, guy replied n what not himself and told me it would work so hopefully ill have a nice lil flywheel here in the near future.
Fronzizzle
Mar 18, 2019 08:29 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
someone972
Aug 30, 2015 12:52 AM
Trickskier
Aug 29, 2015 01:12 PM
