busted up t-5
Old Feb 16, 2005 | 03:27 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
busted up t-5
got a busted up t-5 here and i want to look inside, how do i get this apart?
Old Feb 16, 2005 | 05:01 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
stand on it end in a drain pan for a bit
knock the roll-pin down in the shift gate block so it'll let the main shift rail move out of that block.
pull the tailhousing, holding the shift gate block in place with your thumb so you don't lose the spring & ball under it.
remove bolts to remove the top cover.
Old Feb 16, 2005 | 05:33 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
thanks figured it out
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
