how to change the rear axle bearings
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey guys im doing a drum to disc swap,and while im at it i will like to replace the bearings and seals.but i have no clue how will i do this.also how does a bad axle bearing feel like?also step by step info will be good
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
rear axle bearing removal
Most common is to use a 3 jaw slide hammer. The 3 jaws collapse to fit through the ID of the bearing, then once through, they are expanded to catch the inside bearing race. then the tool has a slide hammer you slide/sling outward very quickly. Eventually, this will get the bearing out.
Others have used a long pipe. put in from the opposite side axle bearing ID, until it rests agains the inside of the bearing on the opposite side of the axle. Striking the pipe with a hammer while carefully keeping the pipe end on te bearing in place can also pop the bearing out.
red90IROCls1
Aug 25, 2015 06:56 AM
rsrmoore
Aug 7, 2015 08:44 PM
