B&M shift improver kit(not transpack)
Old Feb 23, 2005 | 10:27 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Well I am going to the track in a month for a spring houston thirdgen gathering and I just cant run with my trans shifting as soft as it is so I just to firm it up a little. Now I am wondering what exactly the B&M shift improver kit will do for me and how hard is it install in a drivway on small jack stands. I have heard alot of bad things about the B&M trans pack so I am wodering just how good the shift improver kit is and if those of you who have it like it. Thanks.
Old Feb 23, 2005 | 11:25 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Re: B&M shift improver kit(not transpack)
Old Feb 23, 2005 | 11:38 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
I wouldn't bother going with the shift improver kit. if you are going to do it, just get the transpack. although it is much more involved, the results are worth it. however i wouldn't attempt it unless you are absolutely sure of what you are doing.
Old Feb 24, 2005 | 10:53 PM
IROCaholic's Avatar
Car: 89 Camaro RS
The trans is just about the only thing on the car I dont work on. Really only because of not being able to get the car high enough off the ground to feel comfortable. If I had a lift it would be a different story. I really just want better than shifts without a complicated installation. Would that be how youd describe this kit?
Old Feb 24, 2005 | 11:02 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
yes, the shift improver kit would firm up the shifts, and it is easier to install. if that is all you are looking for than it will be fine.
Old Feb 26, 2005 | 01:32 PM
Whitels1's Avatar
Car: 99 Z28
Engine: ls1
Transmission: A4
Axle/Gears: 3:42
I put one in my 84Z28 when I was 18. My 700r4 was slipping a little from 2-3 and after the kit and B&M trick shift it was good. It's not to rough just messy and you need to take you time.
Old Feb 26, 2005 | 09:08 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The kit sucks, only usefull thing in it are the gaskets. It will make it shift harder but will do nothing to improve transmission life like the transgo kit does. Word of advice do not use the street strip option unless you like neck snapping transmission breaking shifts. If you do a search for B&M kit I have posted a couple of non book methods using peices from the B&M kit that dont damage the transmission as badly but still give firm shifts.
Also suggest you adjust you tv cable a couple clicks tighter before you go buy the kit.
J-money
Jan 4, 2019 09:45 AM
86Firebird86
Dec 26, 2015 07:21 AM
hdis2002
Sep 8, 2015 02:52 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
