New FLywheel
Old Feb 28, 2005 | 06:07 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
New FLywheel
i have an 86 z-28. it has a built 356 in it, but i am currently using the stock flywheel. i have been reading about light weight flywheels and was curious on anyone else that may have a lightweight flywheel in the cars?
in know the stock flywheel is 27-32lbs, and the new flywheel is could be as light as 15lbs.
can anyone give me some insight on the pros and cons of a lighter flywheel. also can anyone recommend places to buy one from.
i know the lightweight flywheels come in aluminum and lightened steel. i was interested in the lightened steel one. (trying to keep cost down).
any info would be great. thanks
Old Mar 1, 2005 | 10:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
GM still sells the 15 pounder (my cost $183, I believe). These were used stock in L69 cars--and other GM cars. You might consider a search.
JamesC
Old Mar 1, 2005 | 04:59 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
you say "my cost" 183 or in the ball park. where can i get it for that price? do u have a part number and a web site? also the stock flywheel on a 305 4bbl was the 27lb correct?
Old Mar 1, 2005 | 05:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The stock flywheel on some 305 4-barrels, the slow ones, was 27 lbs. The stock flywheel on others, the fast ones (L69 and LB9 specifically) was about 16 or 17 lbs. That's the one James is talking about.
Both are stock.
Old Mar 1, 2005 | 06:00 PM
JamesC's Avatar
As I say, I purchased mine directly from GM. The part # is 14085720. Check the following link for another option (shipping is stiff):
http://www.gmpartsdirect.com
JamesC
Old Mar 1, 2005 | 09:51 PM
brutalform's Avatar
Re: New FLywheel
any info would be great. thanks [/B]
I would check with the maufacturer of the flywheel. Im not totally sure, but I think a heavier fly in a 3500 lb. car, with a mild engine.
Then there is the lightweight fly, in a 3500 lb. car with a stroker yielding good torque numbers. The makers can shed some light, as there are a few things to consider. Too light, or too heavy with the wrong combo, would not be desireable.
Try SPEC, McCloed. These are two reputable sources.
Old Mar 2, 2005 | 12:05 AM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
hey thanks for all the help guys...the one last question i have is that the flywheel recommended is for a two piece rear seal and for cars older than 85. my camaro is an 86.. and my motor is a brand new built 350 4 bolt bored 040 over. for a 356ci. i know there has got to be a differnce, if there is any?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
