backlash
Old Feb 28, 2005 | 08:16 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
backlash
i just put in a posi and 3.42, i have the backlash at about 13/1000. now ive heard this can be both exceptable and too much. it does have quite a bit of whine. does anyone have any input?
Old Feb 28, 2005 | 08:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's too much. .005" - .008" is better.
What pinion shim did you use? What kind of gears?
It should be all but inaudible. No stock type gear set should whine.
Old Feb 28, 2005 | 08:33 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
my pinion depth is fine. the recommended backlash is somewhere between 7 and 12 thousands. the gear set and posi is out of my friends '02 ta which only had about 10,000 miles on it at the time he took it out. the gears already whined before he pulled it all out. im probably gonna pull it out and shim it over a little bit but i wanted some opions first
Old Feb 28, 2005 | 08:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If the bearings are new, use less backlash. Those numbers look like the recommended ones for used bearings (check while in service, not a rebuild spec).
gord327
Oct 3, 2015 01:25 PM
dimented24x7
Sep 17, 2015 06:58 AM
camarokev400
Jun 30, 2005 10:29 AM
25THRSS
Feb 6, 2004 05:27 AM
alloy
Nov 27, 2002 01:33 PM
