700r4 reverse input drum
Old Mar 1, 2005 | 11:31 AM
Alex99's Avatar
Hi,
I want to know if the reverse input housing aka drum is the same for the 700r4, 4L60 and 4L60e.
If not can I use a 4L60e drum in a 1991 700r4?,
The part I'm talking about (not mine!)
Also, wher can I buy a good used or new reverse input drum?
Alex
Old Mar 1, 2005 | 01:40 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If memory serves,82-86 is one design, 87-92 is the second design. They were again changed for 93.
My book shows the 93 version as being interchangable between the 700r4 and the 4l60e. However, the 93 housing CANNOT be used on the 87-92 models but CAN be used on th 82-84's. Confused? So am I.
Old Mar 2, 2005 | 04:01 AM
Alex99's Avatar
Really, this is kind of hard to understand.
How do the differ? I read something about different sizes of the feed holes. Does anyone have any hole sizes?
I checked the hole in the worn drum I have. Its 3/32 in diameter. The hole in the pump shaft is 7/32 in diameter.
Any idea where to get the right drum for my application?
Alex
Old Mar 2, 2005 | 07:09 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
The housing feedhole was downsized to .095 in 87. In 93 it became a large square hole. The only place I know of to buy the drum is gm dealer. $90 or so. The trans has a date code cast into the side . It also has a code stamped in the pass side pan rail flange. This contains the julien date and suffix code so the dealer can sell you the drum you need.
Old Mar 2, 2005 | 05:21 PM
chris718's Avatar
look here they are all interchangable as long as you use the hardware that comes with each assembly.the piston type and clutch thickness as well as the cushion plate have changed over the years so just order a loaded drum any year.the diameter of hole that feeds the drum is the only difference in oil routing that changed.i interchange all the time,no problem.need a drum loaded ?contact us 65.00.
Old Feb 16, 2011 | 03:21 PM
Teod83's Avatar
Car: '91 Pontiac Firebird
Re: 700r4 reverse input drum
Same problem... I'm looking for this piece, good information on this post!
Old Feb 17, 2011 | 11:10 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
You can check WWW.bulkparts.net or a cheaper spot WWW.800700tran.com
Hotrodboba400
Dec 10, 2019 07:07 PM
devilschariot
Feb 25, 2016 03:08 AM
Prodigious
Sep 18, 2015 05:23 AM
Prodigious
Sep 18, 2015 05:18 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
