Gear pattern question
Old Mar 5, 2005 | 01:16 AM
jonarotz's Avatar
Car: 91 Z28
Is this caused from too little backlash?
http://www.jons91z28.zoomshare.com/a...0068880/:album
Old Mar 8, 2005 | 10:12 AM
Precision Trans's Avatar
What's the actual backlash as measured with a dial or test indicator? If you can't tell me, then you are not properly equipped to handle working on gearsets and you should consult someone with experience. Best to spend a little money now on a professional, than alot more later if you ruin a gearset.
If you have any questions please do not hesitate to contact us
Don
Old Mar 8, 2005 | 10:17 AM
jonarotz's Avatar
Car: 91 Z28
I set these gears up with .008" backlash, They have a few thousand iles on them. I just upgraded my posi carrier and noticed the pattern.
Old Mar 8, 2005 | 10:20 AM
ede's Avatar
ede
.008 ought to be good, i always try for .008 to .006
Old Mar 9, 2005 | 06:25 AM
How does 0.008" compare with the manufacturers recommendation? I hope you didn't pick 0.008" arbitrarily, when setting the baclklash. You must bear in mind, that the tighter you set the backlash, the less room there is for lube when the gears are in mesh. U.S. Gear recommends 0.008" to 0.012" for their gearsets, and Ford Racing Recommends 0.008" to 0.015" with 0.012" to 0.015" preferred. Setting your backlash to the high side of the range will allow best lubrication without sacrificing gear life. If you have any further questions, please do not hesitate to contact us.
Don
Old Mar 9, 2005 | 01:54 PM
jonarotz's Avatar
Car: 91 Z28
No I used the spec given by Richmond. I had it at .008 and this was the pattern on the pinion. I just thought it looked funny. The gears would whine on decel., now with the new zexel torsen I set the backlash at around .010. hopefully this will quiet them down. I was mostly curious if the backlash was too tight and if that was the source of my whine.
Old Mar 10, 2005 | 08:33 AM
Okay, now that I know the gear manufacturer, I may be able to help you track down your noise.
69 series Richmond gears are meant to be set up with the contact pattern biased towards the toe on the drive side and the centre of the tooth on the coast side. If you set the pinion depth so that the drive side pattern is central on the tooth, then the coast side will be biased towards the toe and your chances of a noise are greatly increased.
Remember, the pinion depth spec. painted or engraved on the end of the pinion is there for a reason. Use it, and you will have alot fewer problems.
In the case of an OEM gearset, you can usually use the original pinion depth shim FOR THE HSG. and set the backlash in the 0.008" to 0.012" range, and your pattern should be okay.
If you have any further questions please do not hesitate to contact us.
Don.
1992 Trans Am
May 10, 2023 07:19 PM
junkcltr
Aug 2, 2019 11:12 PM
crazynights
Aug 21, 2015 06:53 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
