Shifter linkage help...
Old Mar 14, 2005 | 03:06 PM
92CamaroLS1's Avatar
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
Those of you with 4l60e swaps, what did you do for shifter linkage. I bought shift lever from summit that supposed to hook with the stock thirdgen shift cable and it does but I can only get the shifter to pull it back from Park to Neutral to Reverse to OD to D and it gets hard when putting in to 2nd and 1st due to the leverage(which im still tryin to solve). However I can not get it to push the shifter lever forwards from D to OD to Reverse ect ... I can physically put it in park but the cable doesnt put the trans in park. Any ideas or other ways of hooking it up? Thanks
Chris
Old Mar 15, 2005 | 01:07 PM
anyone??
Old Mar 16, 2005 | 12:32 PM
Ive searched around and I havent found any answers so far...I know there has to be quite a few 4l60e swaps...how did you guys handle the shifter linkage??
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
