clutch / flywheel problem
Car: 1994 Jeep Wrangler
Pressure plate wont fit flywheel! I just bought a T-5 setup from a 91', and it came with a center force clutch. Anyways, i have an 85' with a two piece rear main, and i got a new fly wheel (i knew the one from the 91 wouldnt fit) And the pressure plate is too small and wont bolt up (not even close) What is wrong? Did i get the wrong flywheel, or is the clutch setup from a 1 piece car different from a two oiece car? HELP ME ASAP!
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
Sounds like you got the larger 168-tooth flywheel set up for the 11" clutch. The 91 uses a 153-tooth flywheel setup for a 10.4" clutch
I am going to pm you I live in Streamwood not far from you I might be able to help you out
Car: `86 SS / `87 SS
Re: clutch / flywheel problem
No, they did NOT change the clutch specs from 1985 to 1986 when they went one-piece RMS.
You probably do have the 168 flywheel from the sounds of it.
Flywheels Quick Reference Chart
Part Number
Outside Diameter
Year
Crank Flange Bolt Pattern
Clutch Diameter
Starter Ring Gear Teeth
Notes
14085720
123/4"
1955-85
3.58"
10.4"
153
Lightweight nodular iron flywheel. Weighs approximately 15 pounds. For two-piece crank seal.
3986394
14"
1970-80
3.58"
11"
168
For externally balanced 400ci small-block V8 only.
Use with balancer P/N 6272225.
3991469
14"
1955-85
3.58"
10.4", 11"
168
10105832
14"
1986-up
3.00"
11", 11.85"
168
For one-piece crank seal.
14088646
123/4"
1986-up
3.00"
10.4", 11"
153
Lightweight nodular iron flywheel. Weighs approximately 16 pounds. For one-piece crank seal.
14088650
123/4"
1986-up
3.00"
10.4"
153
Standard weight flywheel for one-piece crank seal
Chevrolet Small-Block V8 and V6/90 Automatic Transmission Flexplates Quick Reference Chart
Part Number
Outside Diameter
Year
Converter Bolt Pattern*
Notes
471598
14"
1970-85
3.58"
10.75", 11.50"
168
For internally balanced engine with two-piece crank seal.
471578
14"
1970-80
3.58"
10.75", 11.50"
168
For externally balanced 400ci small-block only.
471529
123/4"
1969-85
3.58"
9.75", 10.75"
153
14088765
123/4"
1986-up
3.00"
10.75"
153
For one-piece crank seal. Used with 5.7-liter HO engine.
12554824
14"
1986-up
3.00"
11.50"
168
Heavy-duty flexplate with increased thickness for one-piece crank seal.
14088761
14"
1986-up
3.00"
10.75", 11.50"
168
Part Number
Outside Diameter
Year
Clutch Diameter
Notes
14085720
123/4"
1955-85
3.58"
10.4"
153
3986394
14"
1970-80
3.58"
11"
168
3991469
14"
1955-85
3.58"
10.4", 11"
168
10105832
14"
1986-up
3.00"
11", 11.85"
168
14088646
123/4"
1986-up
3.00"
10.4", 11"
153
14088650
123/4"
1986-up
3.00"
10.4"
153
Part Number
Outside Diameter
Year
Notes
471598
14"
1970-85
3.58"
10.75", 11.50"
168
471578
14"
1970-80
3.58"
10.75", 11.50"
168
471529
123/4"
1969-85
3.58"
9.75", 10.75"
153
14088765
123/4"
1986-up
3.00"
10.75"
153
12554824
14"
1986-up
3.00"
11.50"
168
14088761
14"
1986-up
3.00"
10.75", 11.50"
168
BlackphantomZ28
Apr 24, 2016 08:14 AM
