clutch fork / pivot screw question
Old Mar 19, 2005 | 10:45 AM
johnny82vert's Avatar
Car: 1993 SSP mustang coupe/1982 Z28 convertible 5.0 5spd.
just got a used bellhousing for my t5 to replace the cracked one so I remove the old clutch fork from the damaged bellhousing to install it on the new one and when I slide the fork onto the pivot ball the clip is very loose where the fork just slides off by itself.
Now I know there is no adjusting the pivot screw on the bellhousing so I would think that the clip has lost it's tension, if so would you recommend trying to alter the clip to maintain tension to the pivot ball or just buying a new replacement fork?
Attached Thumbnails clutch fork / pivot screw question-c-documents-settings-owner
Old Mar 22, 2005 | 09:34 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Replace the fork and the pivot ball if you can. Both wear out and fail at the worst times, don't forget to grease both the ball and where the throwout bearing rides. The forks also have a habit of bending over time, and unless you have a new one to compare it to, you'll never know.
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Sep 17, 2020 08:26 AM
Ghettobird52
Apr 21, 2020 08:44 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
