clunking sound, feels like trans/motor mount but isnt
Old Mar 20, 2005 | 02:02 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
for a few weeks i've had this clunking in my car under hard acceleration, and for a few months, theres been huge amounts of wheel hop when i spin the tires in reverse, but at first it would take a flogging in the forward gears without any sign of clunking or hop. it feels just like a transmission mount, i had that go out on my old camaro, and it felt the same, so the first thing i did was get an energy suspension transmission mount. after i put that on, there was massive vibration, revving it in park would rattle things in the car and felt very bad, and it didnt fix the clunk, so i put the stock one back on, then replaced the motor mounts, which was a major PITA, after a local "speed shop" charged me 65 bucks to tell me it was the motor mounts. any ideas what could cause that type of clunk besides the mounts, and any other bad experiences with the energy poly transmission/motor mounts?
Old Mar 20, 2005 | 02:05 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Yes...the torque arm mount on the trans....or a bad u-joint. The bad torque arm bushing would be felt under hard acceleration.
Old Mar 20, 2005 | 02:17 PM
1meanGTA's Avatar
how do i go about checking the torque arm mount? i'm pretty sure the u-joint is alright, i can turn the driveshaft maybe a 1/4 inch side to side, but everything seems tight back there. could a torque arm cause the wheel hop in reverse? i've never noticed any wheel hop in the forward gears.
Old Mar 20, 2005 | 02:23 PM
1meanGTA's Avatar
by the way, how do you like your slp CAI? i've been considering one but they're kind of pricey, any pictures of it?
Frozer!!!
Jan 19, 2024 04:55 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
db057
Aug 22, 2015 08:17 PM
BlackBoulder
Aug 11, 2015 11:15 PM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
