wat cause a noisy rear end
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey guys i have a buddy who bought a 91 z and that rear end wines like a monster.it quites down after like 60 mph.wat causes a wining rear end?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i heard that misalignment of the pinion and ring gears can do that, as well as chips on the teeth
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Crush collar crushed more than it's installed dimentions due to hard launches is the most likely culprit. Is it leaking at the pinion seal?
Engine: SBC, LS-x
Come to think of it, it ould be other things too.
Does your friend know the history of the car, rear end work in paticular? If the gears were not set up right initially that would do it. Used gears not set up exactly as their initial install will do it. Will never get rid of the whine either without replacing the gears. Might quiten it down a bit by resetting them but never get rid of the whine completely without replacing them
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
if it's a hunting or semi-hunting gearset (depends on ratio)and it was removed and re-instsalled without the gears in the same position it will make noise
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
