need new rear end
Old Mar 24, 2005 | 09:56 PM
blue_tacos's Avatar
Car: 82 Berlinetta 87 Iroc
Engine: 327
need new rear end
I have an 87 Iroc with a stock rear end with 3.23 gears according to the chart here at the site without posi and I'm assuming its 26 Spline. What are all the parts I need to get to so it will hold around 450hp and a kid driving it
Old Mar 25, 2005 | 01:38 AM
VILeninDM's Avatar
http://www.ws6transam.org/10bolt.html
<-- do everything that says
.... and then according to experts you should be good for 400hp. One thing I was never sure about if that 400 they through out in there was at the flywheel or rwhp. I am assuming flywheel, but that's only because I planning to build an engine with roughly similar numbers
If I were you I'd start with 4th gen rear just so you can get disks at the same time and you can probably find one with a posi and a ratio you want. That's what I did and I decided to keep original posi until it becomes open diff and then I'd probably put auburn in there.
Also there is a better cover made by TA.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
