teeth or spline?
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
teeth or spline?
This JEG's catalog lists the 3.23 gears i want but it lists teeth number, which is 42-13...what does that mean? and i found this auburn posi diff., says 26 spline, will that be a problem since the 3.23 gear in the jegs catalog is 27 spline?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They're talking about entirely different things. The number of splines on the posi has to match the number of splines on the axles. The number of teeth on the gears determines the ratio, 42 / 13 = 3.23. That has nothing to do with the splines.
Car: '94 Z28
Engine: LT1 350
oh dang...so i'm going to have to buy a whole new posi unit, gears and axles? that's going to be near a grand then to turn my 2.92 non-posi into a 3.23 posi huh?
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I don't know where they got 27 spline from, 7.5" 10 bolts are either 26 or 28 spline, depending on year, they went to28 spline between 88, 89 and 90, depending on who you argue with(I'll stay out of that one)
dimented24x7
Sep 17, 2015 06:58 AM
