tranny stuck in low gear
Car: 70 el camino
Transmission: th350
I'm looking to get a 85 z28 carb and the tranny is stuck in low gear...I was just wondering if anyone had any suggestions on what I could do to fix this...thanks a lot
Car: check
Engine: check
Transmission: check
Re: tranny stuck in low gear
RBob.
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Re: Re: tranny stuck in low gear
Originally posted by RBob
If you mean it never shifts out of low and reverse works properly, then it may be the governor gear is stripped. Common problem.
RBob.
RBob.
Car: 70 el camino
Transmission: th350
I was also told that somewhere on there it has a little plastic clip that can cause it too...any truth to this? also what could I do to fix this and price range on that? you guys are gods by the way
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
If it is just the gear you could just change the gear. If you do it your self it would be a couple dollars for the gear. It could also be a sticking throttle valve in the valve body. Without being able to drive the car it is very difficult to diagnoise the trans.
