rear end gears
Old Apr 4, 2005 | 09:42 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
rear end gears
I have a rear end out of a 84 H.O. camaro. the castings said it has a posi with 3.73 gears. i opened the cover and did not see any springs or clutches. the gears still are 3.73. Do all camaro's have the same size rearend gears 7.5 or 8.5 i don't know what i have. do i have to measure it? any help would be appriciated. thanks
Old Apr 4, 2005 | 09:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's a 7.5. All 82-up Camaros have that, except for ones with the 9-bolt (some had that in 86 or so up to 89) and a very very few with a Dana 44. So few of those, it's not worth worrying about.
3.73 open was real common back then. That's how my 83 HO car came. It's probably better that way though; alot of them that had "posi", it was actually an Eaton Gov-Lock. Basically, shrapnel from the future. Although the open that was in the car, somehow miraculously turned to shrapnel one day... go figure....
Count the teeth. Ignore the codes. 3.73 will have 11 on the pinion and 41 on the ring.
Old Apr 4, 2005 | 10:49 PM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
There are some #'s stamped on the Ring Gear. Just turn the ring until you find them. Like what was said above, if you have 3.73's you will find 41, 11 stamped on the Ring Gear. Just devide the larger # by the smaller # you find on the ring gear.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
