T56 Questions
Old Apr 7, 2005 | 10:52 AM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
T56 Questions
I am upgrading to a 350 soon and I don't think my current T5 will last much longer with a motor making more power so I was thinking of going to the t-56 and I have a couple questions.
1. What year and model cars can I pull a t-56 from that are easiest for the swap? or which ones can I buy new?
2. Does it take the same clutch as the t5 or is it different?
3. What is needed to hook it up to my current speedo?
4. Are there any driveshaft mods that have to be done?
Old Apr 7, 2005 | 10:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
1. 94-97 (LT1)
2. No, it is different. Get the trans, bell housing, flywheel, clutch, hydraulics, shifter, and all hardware. You'll need them all.
3. Go to www.jagsthatrun.com and take a look. They're about the only source I know to buy one already prepped. Although, it's not all that hard to do, so you might be able to find somebody that can do it for you.
4. No.
5. You'll need an aftermarket crossmember; neither the 3rd gen one nor the 4th gen one will fit and work. I'd suggest getting a crossmember/torque arm combo, such as from Spohn.
Old Apr 7, 2005 | 03:22 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Originally posted by RB83L69
1. 94-97 (LT1)
Why not include 93?
Old Apr 7, 2005 | 03:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Different gear ratios, weaker
Old Apr 7, 2005 | 03:41 PM
cali92RS's Avatar
Car: White KSwisses
Ohhh
Old Apr 7, 2005 | 04:51 PM
91Z28-350's Avatar
FWIW, road race guys prefer the gear ratios on the 93.
Old Apr 7, 2005 | 07:37 PM
BOTTLEDZ28's Avatar
Transmission: A4
yes they do, but they also have a much better built T56. For the ones that dont know, the 93 T56 has a 3.08 first gear and the 94-97 has a 2.97 first gear,,,,or was it 2.66.
Old Apr 7, 2005 | 07:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
2.66
What is so "much better built T-56" about the ones with the smaller clutch gear?
Old Apr 7, 2005 | 10:09 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
So how difficult is it to get the T56 to work with a cable driven speedo??
Old Apr 8, 2005 | 06:39 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
https://shell7.tdl.com/~jags/Pages/P...ilHousing.html
Just look, a pic is worth 1000 words
Old Apr 8, 2005 | 08:24 AM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
So it looks like it would be easier to buy the tailhousing from them??? Man this is getting expensive
Old Apr 9, 2005 | 07:34 AM
kevinc's Avatar
Car: 1982 Z28
Originally posted by cali92RS
Why not include 93?
Because he's done research and knows what he's talking about...
Old Apr 9, 2005 | 10:50 AM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Is modifing the tailhousing simply switiching out parts, or is there some fabrication required??
Old Apr 9, 2005 | 03:33 PM
kevinc's Avatar
Car: 1982 Z28
The Jags That Run thing RB posted is a straight bolt-in, no fabrication needed.
19irocz85
Aug 26, 2015 07:54 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
