checking U-joints?
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
checking U-joints?
Is there a good way to check your u-joints? If you get under the car and try to wiggle the drive shaft will that do it? Another question is do they need lubed? I didn't see a zerk.
thanks for the help,
phil
phil
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
They need lubed. There is a zerk. Because of the tight fit, the fitting on my grease gun won't work. I have to take it to a service station.
JamesC
JamesC
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
only aftermarket replacement ones have a zerk fitting, the factory ones that were origanally installed were sealed and pre-lubed
Now I think about it, 84Z, you're correct--and mine are after market
JamesC
JamesC
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Engine: 383 Carb
Transmission: 4L60
Usually you can inspect them visually for any slack as you rotate the shaft by hand. U-joints are sort of like wheel bearings in that they're cheap enough that if you have any doubt as to whether they're worn or not, they should just be replaced.
BumpaD82
Feb 26, 2016 02:57 PM
Numbah-1
Sep 12, 2015 08:57 PM
