LS1 rearend (tried searching)
Car: 89 Iroc
Engine: 305TPI
Hello all I tried searching on this and couldn't find the article. I am going to be doing the swap here shortly but couldn't find some of the posts I needed. I have downloaded the tech article and have read through it. I am trying to find out about the brake line problems. I know that you will need to cut and flair the brake lines but where? Also what modifications need to be made to get the e-brake cable to fit? If someone could point me in the direction of the articles it would be great, that way no one would have to retype anything.
Also on a side question. Would you guys recommend changing out the master cylinder if I have drum brakes now? I know the proportioning valve will need to be changed but there seems to be some debate whether you need to change the MC or not. Thanks.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
for the hyd brake lines:
if it had TCS, its going to have two brake lines coming off the axle. you need to reduce this to one.
i havent done it myself, mostly because all of my 4thgen rears are from non TCS cars.... shouldnt be too hard with a nice T fitting... similar to stock.
for the parking brake:
you need to make or find a way to hold the cables in the trans tunnel.. once its on, you'll see what i mean.
the master cyl for thirdgens(except 82-82 iron ones) are the same for drum and disc brakes.. only the prop valve is diffrent.
Car: 89 Iroc
Engine: 305TPI
If memory serves me right there are two lines going to the brakes. I will take a look at the rear brakes on my car to understand the t-fitting you are talking about. I also read about the brake cable but was trying to understand it, so I guess that is another thing I will figure out soon enough.
So do all of the lines connest without any problems or will there be some modifications involved with the swap?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
This is what I did on my car.
I used the stock rubber line off of the body to the stock T fitting and then got 2 lengths of hard line to go to the ebrake cable bracket where the rubber and hard lines attach to the caliper.
The 2 lines I bought cost about $8. one was like 18" and one was like 22", but I would measure it just to be safe.
Car: 89 Iroc
Engine: 305TPI
So that is really the only changing you have to do to the brake lines? I could have sworn I read somewhere that you had to do some pretty significant changes to the brake lines. Thanks for the help with this.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
86White_T/A305
Sep 21, 2015 05:28 PM
