Flywheel Question
Old Apr 13, 2005 | 01:14 AM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Flywheel Question
I am switching to a CFDF clutch when I do my motor swap and I know I should probably change the flywheel at the same time since it has already been resurfaced once. What is a good flywheel to go with??
Old Apr 13, 2005 | 09:39 PM
brutalform's Avatar
Why not go with a new original. C/F also sells flywheels now too. Should you replace it if it was only cut once? I believe that C/F will want you to resurface it anyway, as you install your new clutch.
Old Apr 14, 2005 | 02:02 AM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Well we are doing the install at my house along with the motor so I won't be able to resurface the current one so I figure I might as well get a new one anyway. So you think just a plain jane stock replacement will work best?
Old Apr 14, 2005 | 02:08 PM
brutalform's Avatar
I dont see why not? I used mine with my old D/F set up with no problems.
Old Apr 14, 2005 | 02:23 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
GM has two different flywheels, the standard 25lb one for L03 & LG4 models & a performance lightweight one at 16lbs for L69 & LB9 engines. (actually 4 different flywheels: 1 piece rms 25lbs, 1 piece rms 16lbs, 2 piece rms 25lbs & 2 piece rms 16lbs)
Old Apr 14, 2005 | 04:15 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
So I should go with a flywheel from a L69 or LB9 engine instead of one for the L03?
Old Apr 15, 2005 | 08:21 AM
Engine: 5.7, 5.0
I would, but it's really up to you. The lighter flywheel might make it a little more difficult if you drive in a lot of stop & go traffic.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
