Posi Install Guide
Old Apr 14, 2005 | 09:37 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Posi Install Guide
This is the guide I am using for installing my posi.
It seems very useful, however is it missing anything?
LSD Install
Old Apr 15, 2005 | 06:45 AM
ede's Avatar
ede
yeah he left out all the important stuff and told you what you should be able to figure out or find in your manual.
Old Apr 16, 2005 | 10:57 AM
Car: 91 Camaro RS
Well I know he has it relatively basic, so what is he missing, I've done searches.
Old Apr 16, 2005 | 06:08 PM
ede's Avatar
ede
back lash and contact pattern would be two biggies. he should also mention the original shims don't have to go back in, or in the original place, however the total shim thickness can not be changed, the arrangement can. since he left out a couple major points i wonder if he did what he said, and nothing more, how long it lasted
Old Apr 16, 2005 | 06:52 PM
Car: 91 Camaro RS
I didn't think backlash or contact pattern changed when you just removed the carrier and ring gear. I thought those only changed when you messed with the pinion. I guess I'm wrong.
Old Apr 16, 2005 | 09:59 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
well, backlash is what is most likely to change. pattern (some, depends on just how far the carrier moved the ring gear) I bet the simple swap will be real close but, in these rears close is not enough you need to be dead nuts on. I know I have done it so many times I know what works and does not.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
