How long did your 10 bolt last behine slicks?
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
How long did ya go? I keep hearing how weak the 10 bolt is but I cant afford to go drop $2k+ on a 12 bolt Moser or Strange unit right now.
Just wondering on average how long I can prolong the abuse to my 10 bolt. Right now I have 28" MT street slicks with a 3.73 rear and 3000 stall on a stock ZZ4 motor.
Thanks.
Thanks.
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I run the 28" ET STreets, 3.73 gears, 3500 stall and it has survived so far with a best 60ft of 1.69. The automatics are a bit easier on them than the manuals.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I was in the 1.6x range before I finally installed a 9". There was nothing wrong with the diff when I took it out. I switched to a 9" at the same time I installed a transbrake. I didn't think the tiny ring and pinion would have survived more than one hit off the transbrake. I ran into the low 11's with the 10 bolt.
Aftermarket 28 spline axles
LPW rear cover with bearing cap supports
Welded axle tubes
Solid crush sleeve
4.10 gears
Welded axle tubes
Solid crush sleeve
4.10 gears
gixxer92
Sep 1, 2015 04:32 PM
Beeman
Aug 31, 2015 07:40 PM
