Any computer tuning needed for gear change?
Old Apr 16, 2005 | 01:36 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Just curious. I replaced the factory 2.77 rear with a 3.27 rear and just wanna make sure the car doesn't still think it has 2.77's when it is really running on 3.27's. If that makes any sense. Thanks fellas
Will
Old Apr 25, 2005 | 08:01 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
hey will -
if your still curious . . . yes, the car will think it's still running 2.77's and nothing you can do with computer tuning will help that. Your speedo will read approx. 118% of actual speed. The only way to have it read correctly is to change the driven and drive gears in the trans tailshaft.
Old Apr 26, 2005 | 03:18 AM
norcalz28's Avatar
Yeah I knew that. I was thinking more along the lines of shift points but then I remembered these trannies are still hydraulic rather than computer controlled.
Do you know where I can get the correct drive and drivens for my application? I was really disappointed when I ordered my tranny from por-built, that he sent me a drive and driven that are nowhere near close. On the freeway cruising with traffic at appx 65mph, mine reads 85+ mph. I've kinda gotten used to it, but I would like to throw the correct ones in there one of these days. Thanks man
Will
Old Apr 26, 2005 | 05:54 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
norcalz28 I like the external accessory you have attached to your car. It really makes your car look good.
but to the real question aren't there some cars that come with the 3.27 gears? might be able to snag one off of there or talk to the dealer.
also are you tires stock height?
Old Apr 26, 2005 | 10:52 AM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
There might be some 3.27's laying around, but any dealer or gm parts supplier should be able to order them up for you.
https://www.thirdgen.org/newdesign/f...n.shtml#tranny
scroll down a bit to :
Q: I want to buy speedometer drive/driven gears, what are the part numbers and combinations?
and try here for an easy to use calc
http://www.hanlonmotorsports.com/t5speedo.asp
IROCZ1989
Jan 24, 2016 03:55 PM
jharrison5
Aug 19, 2015 05:53 PM
kyleb24
Aug 15, 2015 08:24 AM
Jake_92RS
Aug 11, 2015 10:39 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
