T-5 transmission
Old Apr 18, 2005 | 05:53 PM
Iroc Tony's Avatar
Car: 86 Iroc Z-28
Engine: 305 carb
Transmission: Turbo 350
T-5 transmission
How do you get the top off of the transmission? Pleas help.
Old Apr 18, 2005 | 06:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The extension housing has to come off first.
Before that, the little block thing that the end of the shifter fits in, has to come off.
Get yourself a 1/8" pin punch, and drive the little roll pin in that holds the block to the rail, SLOWLY AND GENTLY; go just a little at a time, until the block is free to slide off the round shift rail shaft. Looking at the shaft, it should be pretty obvious how far you need to drive it. DO NOT drive it too far, or you will never be able to get it apart.
Once you've done that, turn the trans up on its front end on top of something so that it's sitting on the case, not on the clutch gear or the clutch gear bearing retainer; and remove the ext hsg. When you get that off, the block will fall out (along with a ball and a spring); drive the roll pin all the way out of the block.
Then remove all the bolts from the "inspection cover", and it will lift off.
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
DARKmj16
Sep 9, 2015 04:07 PM
