all pistol grip owners inside
having troubles installing my pistol grip on my 88 700R4. so if someone else has succeeded, what did ya do with your tv cable. where does it go? please help
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The TV cable goes to the throttle arm on the carburetor or throttle body. It doesn't go anywhere near the shifter.
then what is that other linkage cable connected to the shifter, it goes to the steering column, the pistol grip has no mountings for it, do i need it, i cant fabricate up nothing until i know how it moves and when. by looking at the stock shifter, it is pulled back when u press the shift button on the ****,
Engine: 383 Carb
Transmission: 4L60
That sounds like the park lock cable, it prevents you from pushing the shifter button to take the shifter out of park without the ignition turned on. If your new shifter doesn't have a provision for it, you can ignore it.
83 Crossfire TA
Sep 18, 2015 12:01 PM
84 TA NV
Sep 6, 2015 08:02 PM
