Dropping Rear...what should be replaced
Old Apr 21, 2005 | 01:49 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
In a couple weeks I will be dropping the entire rear end in my RS and installing a newly built rear.
The question I have is while the rear is dropped what else should I replace on a car which is more less stock with a good number of km's? I dont need something which is really Hi-po....but if I got the rear diff out of the car what other suspension parts should I replace/upgrade because of wear?
I have thought about the following: Shocks, springs, LCA's, endlinks?
other suggestions????
Dave
Old Apr 21, 2005 | 02:45 PM
ede's Avatar
ede
shocks, bushings, and i'd consider the fuel pump
Old Apr 21, 2005 | 08:59 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
fuel filter
TheExaminer
Aug 26, 2015 04:59 PM
Winchester1094
Aug 18, 2015 10:23 AM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mizz0313
Aug 12, 2015 06:45 AM
