rear end noise
Old Apr 25, 2005 | 10:06 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
rear end noise
hey guys you might remember i recently installed a new auburn posi and bearing well it has been about 3-4 hundred miles since then and i took an extended highway trip proboly like 30 miles at 50+ miles per hour plus some hard lauches as i was on my way home i noticed that if i put my head between the seats and listened i could hear a slight whine proboly from the rear only on light accel not on decel or anything past like half throttle the niose is quite faint barely audible over my flowmaster, but do you think i should be concerned when i got home i felt the cover of the rear end and it was hot like i left my hand on it for about 30 seconds and it knda tingled but not lot burning, should i change the fluid?? cant remeber if it made noise before
ps stock gm 3.73 were swapped onto the new posi and new carrier bearings installed backlash was 8-10 thousands and pattern was ok ???
Old May 4, 2005 | 11:31 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: rear end noise
Is the rearend a 9 bolt or 10 bolt? If it is a 9 bolt, check to see if the noise is coming from one of the rear tires, if it is, then it is probably the bearings pressed on the axle that is bad.
If it is a 10 bolt, then more than likely it is an incorrect backlash setting.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
