86 vette T700R4 trans fit into 86 Camaro
There is a guy selling a T700R4 that he had build about 10,000 miles ago. He has pulled it out of his 86 Corvette. I have an 86 Camaro, so will the trans directly bolt in or are there differences?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The Corvette 700R4 has a shorter output shaft and a different tailshaft housing. You'd have to change those items to use it.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If the trans started out life in a corvette, it positively cannot be used. The vette case is unique. Because the vette trans has no mount, the tailshaft has the mounting provisions for a huge rigid torque beam. This connects the fixed rear to the trans and supports it. Due to this fact the case does not have the holes, or even the bosses, to mount up a trans mount. If the trans started life in any other vehicle, the holes will be there. Check this before you dive in.
84z96L31vortec
Aug 20, 2017 12:16 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
