Factory rear differenial strength.....?
Old Apr 28, 2005 | 01:23 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
How durable are the factory rear ends in these cars? Could they stand a 350-ish horsepower motor or would they need replaced? Thanks.
Old Apr 28, 2005 | 01:30 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Well that depends on a few things such as: tires, posi or open, what type of launch, and torque (not hp even though hp is a function of torque).
Old Apr 28, 2005 | 01:38 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
rear end strength
with street tires and a automatic , dont think you would hurt it but add traction or a stick shift and its only a matter of time , abuddy of mine has a 99 firehawk 6 speed with a stroker motor in it , he autocrosses it on his third set of gears now and he takes it wasy on the clutch domps and no strip use 460rwhp
Old Apr 28, 2005 | 02:24 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I wouldn't plan on running it too hard, but whenever the wrong Mustang in the right place.....I was thinking about getting a 3.2x-3.4x posi and keeping the auto but getting 1200-1800 RMP stall converter. Factory tires, wheels, etc. Not real sure on the torue, but I would guess about 350 give or take 10-20 ft lbs.
Old Apr 28, 2005 | 02:59 PM
Car: 91 Camaro RS
You would probably be alright depending on what tires, but espically on the street where you have less traction you will be alright. I would recommend atleast a 2k stall though.
Old Apr 28, 2005 | 04:13 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I have Cooper Cobras on now and they are less than 2 months old, so they will be there a while. Why a 2000 Stall? Durability, or just the take off factor? Would a posi-trac be better than the factory rear end? Thanks.
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Old Apr 28, 2005 | 04:41 PM
Car: 91 Camaro RS
Acceleration only, especially with 350 ft/lbs.
Looking at your sig it says 91 RS L03, so if you rear is factory then probably odds are 1 in 100,000 or so that it has a posi. You would be much better with a Limited Slip of some brand.
Old Apr 28, 2005 | 04:48 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Limited slip? What brand/gear ratio would you recommend? I was considering pos because of the transplant factor.
Old Apr 28, 2005 | 04:52 PM
Car: 91 Camaro RS
Gear ratio would all depend on the engine setup and where it made the most power. Limited slip, posi, same thing. I would recommend atleast a Auburn that came factory on third gens or early forth gens or a Torsen.
Old Apr 28, 2005 | 05:12 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
The rear end is a 7.something inch nine bolt right?
Old Apr 28, 2005 | 05:40 PM
Car: 91 Camaro RS
From your signiture on the on side you say you have a 91 RS L03 with 700r4 which would come with a 7.625 ten bolt rear.
Old Apr 28, 2005 | 08:10 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Ok. Thanks for all your help. I now feel confident enough not to really mess things up. lol. I found a set of new Auburns for 330 or so.
Old May 15, 2005 | 08:05 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Uh, one more question... how many spline would the rear axle be? Thanks.
Old May 15, 2005 | 09:57 PM
Car: 91 Camaro RS
Your 91, if factory, would have 28 spline axles.
Old May 15, 2005 | 10:53 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Thanks. I thought that, but wanted to be sure for when I buy a rear end for the car.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
novaderrik
Aug 10, 2015 12:44 PM
