Driveshaft for TH350 to TH400 conversion
Old May 2, 2005 | 02:45 PM
WhiteLightnin83's Avatar
Car: 83 Z28
Engine: Mild 383 Stroker
Transmission: B&M TH400 with shift kit
Axle/Gears: 3.73 Limited Slip
well i know i have to cut the yoke of the 400 off and weld onto the 350 driveshaft and i believe the TH350 was a short shaft but when i just set the driveshaft up next to the torque arm to get a rough idea if it was the same size it looked like it was still too long... does anyone know exactly how long the driveshaft has to be from weld to weld for the TH400 tranny?
Old May 2, 2005 | 10:27 PM
Car: 83 Z28
well i posted on camaroz28.com and they told me this site was better for information so somebody has to know what i'm talking about.... someone who's done the conversion wanna chime in?
Old May 2, 2005 | 10:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The TH400 and TH350 are the same length unless you have one of the long tail versions.
Old May 3, 2005 | 11:07 AM
Car: 83 Z28
ok thanks, do you know by chance how long that is exactly so i can find out if i have a short or long shaft? i still have the TH350 sittin in the garage so i could look at it if i needed to. the cone that covers the yoke is about 8 inches long maybe?
Old May 3, 2005 | 03:38 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
if it will help. i replaced 700 for a 400. i installed tha 400 slip yoke all the way in then backed it out 3/4 in. measured center to center on yoke. my stock shaft was to short so i pulled a larger dia. shaft from junk yard and had it cut total cost about $80.
Linson
Oct 24, 2025 02:00 PM
darwinprice
17
Oct 11, 2015 11:51 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
