Noisy first to second shift, need advice
Old May 6, 2005 | 07:52 PM
ladyfirebird's Avatar
Car: 94 Firebird
Engine: 3.4
My automatic (700 R4) makes a grinding noise when it's in first gear and as it shifts from first to second. It hadn't made this noise when up or downshifting to any other gears, just in first and to second. I was driving it today, and it once it started grinding in first as it shifted to second it kept making this sound, only quieter. It's such a strange grind, it's not as sharp sounding as grinding usually is. It's a softer sound, but not a whine. I can't come up with anything that would cause this. Has anyone had this happen to them before or have any ideas as to what it could be? Thanks, I appreciate any feedback.
Old May 7, 2005 | 01:13 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
If you have definately isolated the noise to the transmission. Your planetary gears are blown up, which most likely sent metal into your converter. So better get the trans overhauled asap before it locks up completly.
Josh
J.S. Performance
92firebirdguy
Sep 1, 2016 07:53 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
58mark
Sep 21, 2015 07:21 PM
dimented24x7
Sep 6, 2015 03:51 PM
