10 Bolt
Old May 10, 2005 | 10:37 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
10 Bolt
I finally got a 10 bolt from an 87 GTA, but before i go out and spend money, i had a couple of questions. Since the 10 bolt that i got is drums not disc and my 9 bolt in my IROC is disc, can i swap the brakes? If so what kind of parts would i need(bearings, ect)? I looked in some posts and didnt find any answers
Old May 10, 2005 | 10:39 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
and i cant find any numbers on the rear on to identify it, it just has the tag that its a limited slip
Old May 10, 2005 | 11:01 PM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
Not sure about the Disk swapp.
I had the same issue with finding the numbers on my 10 bolt.
It had so much dirt & oil cake on it I couldn't find any numbers.
But after I sandblasted it, all the numbers were there. They were on the bottom of the pumkin.
Old May 10, 2005 | 11:05 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
koo, but i dont have access to a sand blaster thought :-( oh well ill clean it with a wire brush or something, but hopefully i can make the swap
Old May 10, 2005 | 11:12 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
I've heard of aftermarket brakets for bolting up disk brakes on a drum rear. Never seen them in person.
The numbers are usually on the pass side axle right around the middle facing foreward. Can be hard to see without cleaning it up. Can be hard to see even after cleaning it up.
Old May 10, 2005 | 11:21 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
THanks, now i need to find a website so i can get them, but is the 10 bolt that i got from the GTA better than the 9 i got in my IROC?
Old May 10, 2005 | 11:44 PM
92'Sleeper's Avatar
Car: 92' B4C Camaro
All the threads I've read said the 9 bolt was stronger. I've never owned one, so I don't know personaly. Do a search, I'll bet you'll find many threads about the 9 bolt.
Old May 11, 2005 | 05:40 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Yeah i heard Borg Warner rear ends are stronger, but i wanted 3.42's for my IROC, and since my 9 bolt is in its last days, might as well replace it. Lucky for me i got the rear end for 20 bucks
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
