9 bolt help
Car: 1989 pontiac firebird trans am gta
Engine: 355
Axle/Gears: 327:1 9 bolt
9 bolt help
i own an 89 gta with the 9 bolt rearend. i belive it has 2.77 gears in it because i cruise at 65 mph running 2000 rpm and at 85 it is 2500 rpm. i am starting to experience some swapping in the rearend and i think the diff. is in need of new clutches. i have emailed 9bolt.com with no reply and i do not know of any other company that sells gears and clutch kits or a new diff. for these. also all my rpo codes have been removed for some odd reason. any help would be greatly appreciated.
Doug
Doug
Car: '82 Camaro
Engine: 383
Transmission: TH-350
Re: 9 bolt help
Engine: 355
there is no metal tag on the rearend. does anyone no of a company that sells gears and diff. kits for the 9 bolt.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
not to be mean but, there is so much info on this just do a search. I could spend days helping you and you would gather far more info in 5 min. of searches
Engine: 355
i have searched endless hours and search pages for borg warner 9 bolt, australian 9 bolt, 7.75 9 bolt, etc. cannot find anything.
Engine: ls1, LB9
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
