Incorrect speedo reading
Old May 21, 2005 | 01:48 AM
cuda71ss's Avatar
Car: 1986 Chevy Camaro
Engine: 5.7L 350
I just swapped a 350 into my camaro attatched to a 700R4. I previosly had a 2.8L V6 in it. I swapped the tailshaft on the V6 700R4 to the V8 700R4 to utilize the torque arm mount. Could this be why my speedometer is reading a higher speed than what I am actually driving at or is a V6 700R4 speedometer cable different than the V8 700R4 speedometer cable?
Old May 21, 2005 | 06:44 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
It's not actually a problem with the speedometer cable but the gears that turn it in the tranny tailhousing.
When you swapped in the V8 tranny tail, you put it in with a different speedometer gear combination. I'd recommend removing the speedo gear housing on the old tailhousing and the new tailhousing and looking at the gears. Hopefully you have the same drive gear and would need to swap only the driven gear.
Get back to us with what you find.
Lou
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Stangski09
Nov 14, 2015 01:27 PM
TrevinE
Sep 14, 2015 03:20 PM
andy74
Sep 3, 2015 08:41 AM
