differences in limited slip
Old May 21, 2005 | 02:24 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
I had my 87 camaro on a lift , its got a limited slip in it. I would spin the yoke on the pumpkin (no driveshaft) ...and both tires spin when i turn it. if i try to stop one tire, the other one wont spin either.
however, the 2001 t/a rear i purchased...has discs that are fairly corroded. the rear has 13,000 miles on it...and when id spin that yoke, one side would spin and the other would try, yet if i stopped one side, the other one would still spin. it was low on gear oil however, and the oil has been sittin in there a while. its got the posi additive too im sure, because when i inspected the gears, the oil got all bubbly. the gears looked brand new.
why would there be a difference like that? do discs/drums act different then eachother in that respect? do the tires being mounted on one rear and not the other make any difference?
Old May 21, 2005 | 09:27 PM
ede's Avatar
ede
all that spinning this way and that = monkey spank, means nothing just like the bubbly oil means nothing. then again since you had to cover off to see the bubbly oil it shouldn't of been much of a trick for you to look at the carrier and seen what you really have would it?
Old May 21, 2005 | 09:36 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
it is a posi carrier.
i was just curious as to why one rear would do one thing and why the other one wouldnt.
billybob6110
Sep 23, 2015 01:30 PM
Numbah-1
Sep 12, 2015 08:57 PM
ericjon262
Sep 11, 2015 06:07 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
