driveshaft vibes
Old May 21, 2005 | 02:35 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
driveshaft vibes
My car has the stock alum. drive shaft. Before the car was pretty smooth except when you got to around 60-65 mph it would start to vibrate, and the one time I had it at the track, I noticed it would vibrate really bad on deceleration at the end of the track. I've also noticed that I was getting a lot of clunks when I put the car in reverse, so I changed the u-joints today. Now, the clunks are gone, but there is a vibration all the time now. I shouldn't need to rebalance the drive shaft after swapping u-joints should I? I thought maybe I messed up on the u-joint install. I bought the correct aluminum joints, and the front joint is loose, the rear one is a little stiff, but I can move it through it's entire range of motion ok.
Any ideas?
Old May 21, 2005 | 02:46 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
I'd start by getting it balanced. If you still have a vibe, check your pinion angle.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
