New 700R4, goodies added: 5500RM shift too high?
Old May 25, 2005 | 04:27 PM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
Transmission: TH350 / 700R4 / 4L60E
Axle/Gears: custom GM 8-1/2" 456 posie
I just had my 700R4 rebuilt to bolt to the back of my /87 5.7 TPI
They used a “Beast” shell, raybestos bands and 3-4 clutches, Superior HP shift kit, Superior K-017 hydraulic lock-up, new oversized trans cooler etc. (The K-017 eliminates the need for a computer lock-up or wired switch)
The transmission works very well, but I am having a bit of a hard time setting up the cable adjustment. If I adjust the cable too far out it will not down shift from 2nd to 1st, and if I adjust it in enough to down shift into 1st from 2nd it will not up shift on full throttle until I hit like 5500 RPM.
What RPM should a 700R4 be shifting at on full throttle runs and still be able to down shift from 2nd to 1st with the gas pedal only?
Old May 25, 2005 | 05:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You adjust the TV cable so that it is all the way out at full throttle. You don't adjust the TV cable to change the shift points - wherever it shifts with the TV cable properly adjusted is where it shifts.
You modify the govenor to adjust the shift RPMs.
Old May 25, 2005 | 11:48 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I had a heck of a time adjusting my b&m megashifter to work right with my 700r4. I had trouble getting it to go into park or 1st consistantly.
But now with my th350 it goes in very easy. I didn't even have to readjust it.
Old May 26, 2005 | 08:48 AM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
Thanks, I did not know that, I thought the cable ajustment was for shifts also.
How is the govenor adjusted? do I drop the pan? Is it in the valve body?
Lastly does the shift kit change the RPM of the shifts? or does it just make it shift like it should?
Old May 26, 2005 | 12:33 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Govenor works off of springs. There is a dome on the drivers side near the speedo cable. Prise it off and the govenor will just pull out.
Hotrodboba400
Dec 10, 2019 07:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
TheTraut88
Sep 7, 2015 05:22 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
