2.73 to 3.23 - How much of a difference?
Old May 25, 2005 | 06:45 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I've swapped and altered everything to do with my engine and converter. The only thing that I have yet to touch is the rear end gears. I'm currently running 2.73 and with my 2800rpm converter I feel it's a bit on the sluggish side leaving the line. If I changed to a 3.23 would I be able to leave the line with more pace that at the moment? Also, what is the difference in acceleration when the car is moving between a 2.73 and 3.23?
Thanks for any advice.
Old May 25, 2005 | 07:13 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I'm in the same situation right now. I'll be going with the 3.42s. I think it will be a little better for the 1/4 mile situation. I was thinking about 3.23s but I dont think it will be worth the swap
Old May 25, 2005 | 08:14 PM
Abubaca's Avatar
I went from 2.77 to 3.27. Basically the same as you're thinking about. It makes a seat of the pants difference, but it's not too drastic.
3.42 would be nice, and if I wasn't planning a 6 speed swap, the 3.42s would be in my future. With the 6, well, I haven't even thought that far yet.
Old May 25, 2005 | 08:57 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
When you do it let me know how it goes, I'm going to once I paint my car next month so I'd like to have some input, especially since I'm in little old Leicester.
Numbah-1
Sep 12, 2015 08:57 PM
64Chief
Sep 12, 2015 08:05 AM
J.C. Denton
Sep 8, 2015 05:35 PM
john204481
Sep 7, 2015 03:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
