Looking for sources for two parts
Car: 2002 Formula Firebird
Transmission: 4l60e
Where can I go about buying steel braided transmission line? I hate the way my stock hardlines are bent up after my swap and I would like to change them. I searched and found some posts about having steel braided line but none actually telling where they got it.
Also where can I get a "new style" kickdown cable? I am looking for the ones that are supposedly exactly like a 700r4's TV cable but made for the th350's kickdown.
TIA
TIA
for the braided cable try anyplace the sells preformance parts, liek jegs or summit, or even the makers like aeroquip, if that doesn't work you can try just about every hydrolic shop in the country. how hard did you look for it? not sure what a "new style" kick down cable is ,but i'd look again at the preformace outlets, or the transmission makers.
Transmission: 4l60e
I checked Jeg's and Summit but I wasn't sure if the braided fuel line is the same? Because I didn't see any that say they are specifically for transmissions.
I have never personally seen the "new style" kickdown cables. Just saw posts on here mentioning them.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can use any fuel-resistant hose, there's nothing special about transmission fluid you need to worry about. I use Aeroquip AQP hose.
LT1Formula
20
Nov 14, 2015 12:02 AM
