vibration issue, pinion angle?
Old May 28, 2005 | 09:44 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i have this wicked vibration that starts when i'm on the highway at about 70 mph. first i need to give you some back ground info
removed t5, rebuilt, installed poly torque arm and transmission mount along with a stock replacement clutch, this is when i noticed the vibration, when it happens if i press the clutch it's still there, so it's driveline vibration, i wanted a centerforce clutch, i installed that, re assembled with everything the same, vibration is there but hardly noticeable i was happy!, well i blew that tranny, all i did was install a rebuilt wc t5 did not touch clutch or bellhousing, and bam same vibration is back, does the tranny moving left to right on the crossmember mount affect that? or just pinion angle?
i installed 4 brand new rims and tires and it's still the same, i'm kinda stumped on this one.
Old May 29, 2005 | 08:10 AM
Kevin Vandevenne's Avatar
Car: 87 IROC
have you checked the driveshaft? I had a similar problem with my car. I put a new set of u-joints in and had my drive shaft balanced, and its as smooth as silk now.
Old May 29, 2005 | 09:40 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
this is the 2nd driveshaft, it was the same one when the vibration disappeared when i changed the clutch a 2nd time, now it's back, it's gotta be some kind of alignment issue
Old May 29, 2005 | 10:40 PM
C Murda's Avatar
Car: 91 Z
Engine: Somethin Nice!!
have you checked your pinion angle?
Old May 30, 2005 | 11:02 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
no, not sure how i go about doing that
Jorlain
Oct 8, 2015 01:57 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
greenyone
Sep 2, 2015 03:39 PM
